Home > Forums > Software User Forums > Autodesk Simulation CFD
CFdesign accuracy...
Old   February 14, 2005, 10:22
Default CFdesign accuracy...
PAD
Has anyone had any experience with a software package called CFdesign v7.0?
I'm trying to run simulations on small water coolers but see a lot of inaccuracies in the simulations with regards to the temperature increase of the water. Even though the solution is regarded as converged the energy balance simply does not compute correctly, i.e. the water temperature increase is too high compared to the heat going into the water.
Just wanted to know if I was the only one having trouble with the software package - seems to have a lot of bugs in it.
Regards, PAD
Old   February 15, 2005, 05:11
Default Re: CFdesign accuracy...
A.S.
Hi
My advice is based on general experience
Which turbulence model you are using. K-epsilon and k-omega gives different result. Also the grid size will also matter. Please read your manual and give make grid adapt or remesh the grid to get y+. Typically for two layer k-epsilon turbulence model the value for wall y+ is < 1. Hope it would help.
A.S.
Old   February 15, 2005, 06:06
PAD
Thanks for the reply.
I'm actually running the simulation as laminar - if convergence is achieved shouldn't the energy balance be OK no matter if the solution actually represents the real flow?
/PAD
Old   February 15, 2005, 09:01
A.S.
Yes, It should be
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFDesign V10 and Solidworks 2010 sonodelirii Autodesk Simulation CFD 1 August 25, 2010 20:11
CFdesign problems gaussist Autodesk Simulation CFD 3 July 8, 2009 10:41
Temporal accuracy ganesh Main CFD Forum 0 February 29, 2008 05:32
accuracy of Discontinuous Galerkin Qu Kun Main CFD Forum 0 September 6, 2004 09:19
