Home > Forums > Software User Forums > Autodesk Simulation CFD
How can files be opened on CFDesign
Old   August 6, 2011, 14:44
Smile How can files be opened on CFDesign
mohd
mosman is on a distinguished road
I am using CFDesign V10 trail version. When trying to poen files ( *.PRT or *.asm ) created on solidworks 2004, I couldn't ...... can one help ?
mosman is offline   Reply With Quote
Old   August 12, 2011, 13:33
Zachariah Swetky
swetkyz is on a distinguished road
If you are trying to simply open them, they will not open. You need to create a new design study. During the process of creating a new design study, you will be prompted to select the part or assembly. This should then load the part for you without hassle.
swetkyz is offline   Reply With Quote
Old   August 20, 2011, 00:08
Derrek Cooper
derrek.cooper is on a distinguished road
Launch CFdesign directly from SW with part or Assy opened in SW..
If you don't have access to SW you can save a parasolid file *.x_t
derrek.cooper is offline   Reply With Quote
Old   August 24, 2011, 01:04
Naren
Narenv is on a distinguished road
In the past i have opened files of pro-e ( .prt ) directly from hard disc using CF design, one point you need to take care is the units will be set by cf design software automatically, if you launch CF design from inside a cad tool it will check all units and also use same units
Narenv is offline   Reply With Quote
Old   November 5, 2011, 12:57
yoav
yoavmatia is on a distinguished road
hi there
i also use SW and found that the easiest way to open files on CFDesign is to go for the simple approach.
1. save your file or assembly as a parasolid (X_t file)
2. open the X_T file using cfdesign
P.s. to open Parasolid files using CFDesign, you have to check the check-box for parasolid in the installation process (if you can't find where is the check box - write me back on this thread and i will further on this).
yoavmatia is offline   Reply With Quote
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
