Home > Forums > AVL FIRE
ESE Engine Chamber Modeler tesselation at piston edge
Old   August 9, 2012, 10:56
Default ESE Engine Chamber Modeler tesselation at piston edge
Lukas
luhawk is on a distinguished road
Hello everybody,
I'm currently meshing a cylinder with a pot-like cavity in the piston in ESE Engines Chamber Modeler. Now the problem is that the grid is to coarse to resemble the edge appropriately.
I have found two ways to fix it which are very costly in terms of cell numbers (almost doubling):
1st: putting refinement regions into the 2D template where the circumferential edge appears to be. Works fine but has drawbacks: Doubling in cell numbers, since refinement is is every layer, not just where I want it to be; very imprecise since the location of the edge is not visible in the 2D template so I have to estimate it.
2nd: increasing the number of horizontal layers for the cylinder meshing by ~+30. Works not as good, since the whole cylinder is refined, but has less increase in cell number (increase of about 1/3) and I don't have to estimate any locations.
Since I'm not really satisfied with both results my question is whether it is possible to refine single horizontal layers (like in other software) and i just didn't find the option, or if anybody knows another workaround.
Any help is appreciated, kindest regards,
Lukas
luhawk is offline   Reply With Quote
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 12 April 10, 2013 00:44
Piston Simulation helloworld922 Autodesk Simulation CFD 1 September 9, 2012 22:54
ICEM CFD-- ic engine combustion chamber meshing chetan mundhe CFX 15 July 22, 2012 18:34
Stratified Charge Engine Combustion Chamber Design AdamL OpenFOAM 15 January 27, 2012 20:47
