Home > Forums > Software User Forums > AVL FIRE
ESE Engine Chamber Modeler tesselation at piston edge
Old   August 9, 2012, 10:56
Default ESE Engine Chamber Modeler tesselation at piston edge
Lukas
luhawk is on a distinguished road
Hello everybody,
I'm currently meshing a cylinder with a pot-like cavity in the piston in ESE Engines Chamber Modeler. Now the problem is that the grid is to coarse to resemble the edge appropriately.
I have found two ways to fix it which are very costly in terms of cell numbers (almost doubling):
1st: putting refinement regions into the 2D template where the circumferential edge appears to be. Works fine but has drawbacks: Doubling in cell numbers, since refinement is is every layer, not just where I want it to be; very imprecise since the location of the edge is not visible in the 2D template so I have to estimate it.
2nd: increasing the number of horizontal layers for the cylinder meshing by ~+30. Works not as good, since the whole cylinder is refined, but has less increase in cell number (increase of about 1/3) and I don't have to estimate any locations.
Since I'm not really satisfied with both results my question is whether it is possible to refine single horizontal layers (like in other software) and i just didn't find the option, or if anybody knows another workaround.
Any help is appreciated, kindest regards,
Lukas
luhawk is offline   Reply With Quote
Piston Simulation helloworld922 Autodesk Simulation CFD 1 September 9, 2012 22:54
ICEM CFD-- ic engine combustion chamber meshing chetan mundhe CFX 15 July 22, 2012 18:34
Stratified Charge Engine Combustion Chamber Design AdamL OpenFOAM 15 January 27, 2012 20:47
