Home > Forums > Software User Forums > AVL FIRE
blended fuel in fire
Like Tree1Likes
  • 1 Post By MohammadMehdi
Old   April 21, 2014, 09:09
Default blended fuel in fire
MohammadMehdi is on a distinguished road
I was wondering if someone could tell me how can i simulate spray for blended fuel? I can't understand what changes should i make in general transport model section for blended fuel?
P.S : i have no problem in simulating spray for gasoline but i don't know how simulate blended fuel.(gasoline+ethanol)
Thanks in advanced
MohammadMehdi is offline   Reply With Quote
Old   April 23, 2014, 09:35
Default hi
taoyikai is on a distinguished road
In the spray module, the number of fluids can be set.
With in your circumstance, it should be two, and the type below should be set as the two fuel that you have mentioned
taoyikai is offline   Reply With Quote
Old   April 24, 2014, 04:23
Thanks for your reply
I had done the same thing that you told me. but the calculation does not start (after i run the case a message is appeared your calculation is finished)
I don't have this problem when i run a case with pure ethanol or pure gasoline. So i believe i should change something else too. I would be grateful if you can tell me should i change something else or only changes in property section is enough?
Old   April 25, 2014, 11:18
I have solved my problem. Since some other people may face this problem in some time I am writing the answer:
in a multi-component fuel the evaporation model in submodel section should be changed to multi-component model.
shahrbanoo likes this.
avl fire dual fuel (methane+diesel) combustion simulation khatamnejad AVL FIRE 13 November 21, 2016 03:53
simulate fuel cell with fire shahrbanoo AVL FIRE 1 September 1, 2013 21:25
Simulation of syngas-diesel dual fuel combustion with AVL FIRE bahaaddein AVL FIRE 1 January 28, 2013 06:19
Inflow condition for the liquid fuel pool fire Jianping Zhang Main CFD Forum 0 May 1, 2003 07:24
