Home > Forums > Software User Forums > AVL FIRE
couple chemical kinetics
Old   June 16, 2013, 16:40
Default couple chemical kinetics
amin u3fi
amin_u50 is on a distinguished road
hi kimmhw...
The problem of recognizing the species is solved but during calculation i face to follow message and finish the calculation in the first iteration...
%fire-I-chom_rate, calling solver for homogeneous reactions
%fire-I-chom_rate, progress of ODE solution = 20%
%fire-I-chom_rate, progress of ODE solution = 40%
%fire-I-chom_rate, progress of ODE solution = 60%
%fire-I-chom_rate, progress of ODE solution = 80%
%fire-I-chom_rate, progress of ODE solution = 100%
* 1. Time Step Time = 0.5555555556E-04 dt = 0.5556E-04 *
* Angle = 540.500 dphi = 0.5000E+00 *
ITER I***************** Relative Residual Source Sums *************I I******** Field Values at Monitoring Location 1 *******I
NO. RESU RESV RESW RESM RESK RESD RESH U V W P TKIN DISP TEMP
thanx for help
best regards
amin_u50
amin_u50 is offline   Reply With Quote
Old   June 19, 2013, 21:29
Myunghwan Kim
kimmhw is on a distinguished road
There is no error message.
The calculation crashed just after 1st iteration?
kimmhw is offline   Reply With Quote
Old   June 20, 2013, 01:58
amin u3fi
hi kimmhw...
yes...after 1st iteration the calculation stopped.
M.r kimmhw...I think that in the initial values @(initial values of species) should inters the species values but i don't know what is this value? i think stop calculation due to this...please help me...
thanx...
i need your help
best regards
amin
Old   June 20, 2013, 02:51
Myunghwan Kim
Hi amin,
initial values mean initial values of each species.. simple.
But it shouldn't be a problem.
In case that an user set "0" for all of species, FIRE sets the fraction of last species as "1".
The sum of all of species fraction should be 1.
I think your problem comes from emission module.
When you want to use "general gas phase reaction" + emission, there is a limitation to select the emission model.
Just try to calculate again after deactivation of emission module.
If it is correct, please check the selected emission models in your ssf.
The following emission models can be used for general species transport only :
NO:
-Heywood original
-Heywood + radiation correction
-Heywood + temperature fluctuation
Soot:
-Kinetic Model
-Kennedy/Hiroyasu/Magnussen
-Hiroyasu/Nagl/Strickland-Constable
Old   June 20, 2013, 12:39
amin u3fi
hi kimmhw...
my problem is solved with your help and thank you very much...i wish all the best for you...
best regards..
amin_u50
how coupled chemical kinetics and HCCI combustion in AVL FIRE amin_u50 AVL FIRE 7 March 30, 2021 15:39
I need chemical kinetics amin_u50 AVL FIRE 2 March 28, 2013 09:00
chemical kinetics for LPG krishh FLUENT 0 January 22, 2008 05:22
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
turbulent mixing controlled reaction vs. chemical kinetics controlled reaction Hyeryung NA Main CFD Forum 10 November 11, 1999 03:00
