December 1, 2013, 02:25 |
zero faces in dynamic mesh
shahrbanoo
Rep Power: 13 |
Hi...
I want to make a moving mesh for my SI engine I did it with fame engine plus after it has finished, I tried to give the .flm file data for case, but I noticed that I don't have INI_EX_Port. and I then found that I didn't have any face on outlet part, for example, the faces of BND_Outlet and all faces related to outlet are zero. Could u please help me? Best regards... |
December 1, 2013, 07:20 |
shahrbanoo
Rep Power: 13 |
please I need the answer...
December 2, 2013, 04:11 |
Myunghwan Kim
Rep Power: 13 |
If your Fame Engine Plus is working well, I guess re-mesh generation will be better.
Surely, your surface file should include the selections. Otherwise, I think you can use FMO Editor. After opening *.fmo, you can see many moving sets. And then, you have to load one mesh for each moving set and define selections and save mesh. You have to repeat this process for all of moving sets. |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
Mesh elements shape on faces | Mohsin | FLUENT | 3 | August 17, 2011 02:37 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
