May 25, 2014, 12:01 |
mesh with ESE diesel
shahrbanoo
Rep Power: 13 |
Hi dears
I want to mesh SIDI engine that its injector is not at the center of combustion chamber. as I saw in ESE diesel, I didn't find where to define the injector place.It seems that it can only mesh diesel engines with the injector at the center. Is there any way to define the place of injector? I'm looking forward to hear from u... thanks... |
May 25, 2014, 12:02 |
shahrbanoo
Rep Power: 13 |
it has only z coordinate
May 27, 2014, 16:59 |
Mack
Rep Power: 12 |
Instead of defining only 1 nozzle with 6 holes, you should define 6 nozzles with 1 hole each. It will allow you to set up the nozzle position (coordinate and angle) for each nozzle. Forget about the data on the right (nozzle hole data). Maybe if your injection profile is symmetrical then you can use the standard approach developed by AVL (which suits well diesel injectors). However, if your injector holes distribution isn't, then you should set up it individually. Regards, Mack |
Display Modes | |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
