Home > Forums > Software User Forums > AVL FIRE
single phase boiling in a bottom heated dust
Old   January 16, 2012, 02:55
Post single phase boiling in a bottom heated dust
reza hemmat
rezahemmat1985 is on a distinguished road
Hi dears
I am simulation single phase boiling in a botoom heated rectangular duct via AVL FIRE software . I do the simulation with the software default's values for convergence criteria and under-relaxation factors . but the results devaiate alot with the experimental ones or it diverges . Please guide me how to use the suitable convergence criteria and under-relaxation factors to reach a logical and converge solution .
Thanks in advance
rezahemmat1985 is offline   Reply With Quote
Old   September 8, 2012, 03:21
Maik SUFFA
avlcfd is on a distinguished road
Convergence critareia and under-relaxation factors are important but not the only and cruical factors for stability and accuracy. Strat with checking your physics e.g. initial and boundary conditions in general computational model setup for getting accurate results and good agreement with the measurement. With convergence criteria (if you are using the default one) you will influence on the accuracy and speed and with under-relaxation factors you will influence on speed-up of the simulation. Usually the values for convergence criteria of 1e-5 are a good choice for momentum and continuity equation. For under-relaxation factors the speed of convergency (and consequently the robustness) is influenced. For your case the value of 0.4 to 0.6 for momentum equation and 0.2 to 0.3 should be a good choice (without knowing more details of your problem it's conditions).
avlcfd is offline   Reply With Quote
VOF for single phase? vuccj7 FLUENT 0 April 20, 2011 19:59
Single phase result file for multiphase simulation Kushagra CFX 2 July 8, 2008 21:14
Eulerian 2 phase boiling Brian Siemens 0 July 18, 2005 11:20
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 06:36
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
