Home > Forums > CD-adapco
Axial Fan boundary conditions
Old   April 20, 2012, 20:11
Default Axial Fan boundary conditions
anonymous
HVLS is on a distinguished road
I'm trying to run an airfoil in ccm+ inside a 60 degree far field at a wall rotation of 63 rpm's to calculate velocity distribution across the blade. The issue I'm having is with the boundary conditions, currently I'm trying to run pressure outlet and pressure outlet but it is pulling air in from both outlets..
open to suggestions
or how to set up the simulation with boundary conditions only knowing rpm's
HVLS is offline   Reply With Quote
Old   June 4, 2012, 16:59
eRzBeNgEl is on a distinguished road
maybe u figured already your problem out, but try velocity inlet and pressure outlet, this should be working.
You can also define the flow direction on your boundaries more deeply, just look at the physics conditions (if i remember right)
eRzBeNgEl is offline   Reply With Quote
Thread Tools
Trackbacks are On
CFX does not continue Shafiul CFX 10 February 17, 2011 08:57
Reversing Fan Direction / Cyclic Boundary Conditions dk1 OpenFOAM Running, Solving & CFD 3 October 4, 2010 05:37
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Help with boundary conditions Dan CFX 0 April 3, 2006 11:32
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 18:29
