November 10, 2012, 12:47 |
How to set segregate solver settings
Himanshu Sharma
Rep Power: 13 |
hi,
i have read the tutorial of star ccm+ to understand about the segregated solver but when i am running the solver i am not getting any convergence in my solution i am attaching my setting picture and my convergence graph:conf used:Capture1.jpg,Capture2.JPGCapture3.JPG,Capture4.JPG |
November 11, 2012, 19:46 |
Dont depend on the residuals
Krishna
Rep Power: 14 |
Please monitor the properties (pre,temp or any other) at inlet or outlet and plot the same. u will know the convergence of solution. If you have any critical domains, then add probe point at the place and monitor the properties and plot the same. it will give you clear idea about what is happening in the solution and convergence. I hope it will help you. Please inform me is this helpful to you. |
November 12, 2012, 07:00 |
Thanks for the reply and how to Define Inlet velocity profile and
Himanshu Sharma
Rep Power: 13 |
hi,
thanks for reply.. i have set the monitoring points and monitoring its........i have one more doubt that if i want to set my inlet velocity profile as the parabolic then ,how can i setup this using the macro... do you have any idea regarding this... actually at the inlet condition the inlet velocity is set to be as uniform in star ccm+ but i want to enter with fully developed velocity profile into the inlet section can you help me. ... |
November 12, 2012, 22:07 |
check this thread
Krishna
Rep Power: 14 |
Hi.. Please check the below threads, you will get answer
http://www.cfd-online.com/Forums/sta...-star-ccm.html http://www.cfd-online.com/Forums/sta...ile-inlet.html Last edited by krishnag2002; November 12, 2012 at 22:22. |
Text UI Command to set coupled pressure solver | jonny_b | FLUENT | 1 | May 18, 2011 03:22 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Non positive volume after solver settings | callofduty | FLUENT | 0 | April 8, 2009 04:50 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
