Errors in fixing the surface mesh repair
Old   July 18, 2013, 13:03
Unhappy Errors in fixing the surface mesh repair
Aditi
jog.aditi8 is on a distinguished road
Hi there. I'm using StarCCM+ for my turbulence model. A small cube is placed inside a computational domain. I've attached a picture of my model. The problem is the base of the cube and the base of the domain are overlapping each other. I tried every possible way I know to fix this, it keeps showing me that manifold edges and piercing faces are found. I also tried the merge/imprint function but that doesn't help as well. Can somebody please help me out with this as I really want to get this thing running. Thanks so much in advance.
jog.aditi8 is offline   Reply With Quote
Old   October 1, 2013, 14:43
Smile
rock_bottom is on a distinguished road
Hi Aditi,
It would not be necessary to fix those as you would end up wrapping the outer surfaces of the cube. It should just be fine if you leave it overlapped.
rock_bottom is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
