Home > Forums > CD-adapco
Export to ensight!
Old   January 17, 2000, 06:10
Default Export to ensight!
Anders Jönson
Hi everyone,
I have a question about the built in capability to export the results from StarCD to Ensight format. When I use this command I always get everything as one huge part in Ensight, i.e. I don't get separate parts for different walls, fluids etc. Any input on this?
Regards Anders
Old   January 17, 2000, 08:55
Default Re: Export to ensight!
Joern Beilke
ENSIGHT, LF(case.GEO) (READ ONLY) ENSIGHT, OPTION (WRITE ONLY) Reads geometry data or writes out geometry and/or post data in a form which can be read by the Ensight post-processing visualization program. Post data can be either cell, vertex, boundary or wall data. A typical sequence of commands to write data might be:
cset news type 1
setwrite case.set
cset invert
setwrite case.set
load case.pst
ensi root
mymodel
ensi form bina
ensi all cell case.set
ensi done
The "setwrite" comand is used for this purpose.
Old   March 29, 2000, 06:03
philip
If you bring the parts into Prostar from ICEM then the names of the family are stored in the cell table name. I have an awk script that writes a prostar script to write out results in ensight format grouped by these wall names. If you have written out a part from icem with a name of bert then you get a bert.inp file. If you
awk -f icem2ensi.awk bert.inp
you get ensi.inp
ifile ensi.inp in prostar when you have a result LOADed.
Regards
Philip
File icem2ensi.awk follows:
BEGIN {casename=ARGV[1]
gsub(".inp",""i,casename)
print "setd,"casename".set,all" > "ensi.inp"
print "cset news fluid" > "ensi.inp"
print "setw,"casename".set,fluid_domain,last" > "ensi.inp"
# make up a script that groups cells into sets by name
if (substr($0,0,6)=="ctname")
gsub(","," ")
print "cset news name",$3 > "ensi.inp"
print "setw,"casename".set,"$3,"last" > "ensi.inp"
END {print "direction write" > "ensi.inp"
print "ensi root" > "ensi.inp"
print casename > "ensi.inp"
print "ensi form bina" > "ensi.inp"
print "ensi all vert "casename".set" > "ensi.inp"
print "ensi done" > "ensi.inp"
Thread Tools
Trackbacks are On
ensight batch export Fabian FLUENT 1 November 20, 2005 14:44
Ensight export Fred CD-adapco 0 September 12, 2005 04:22
EXPORT ENSIGHT TRANSIENT Aris FLUENT 0 December 12, 2004 13:50
Export ccm+to fieldview or Ensight? li xinfeng CD-adapco 2 September 10, 2004 15:43
Proam export to Ensight Flav CD-adapco 0 May 2, 2002 09:32
