k-e
Old   February 20, 2000, 09:30
Default k-e
K.L.Huang
in turbulence case alwayse how do you descide the value of k an e?
Old   February 21, 2000, 04:46
Default Re: k-e
allan
On velocity inlets
k=1.5*(turbulence intensity * velocity)^2
and in general
ep=cmu^.75 * k^1.5 / length scale
cmu = 0.09 usually
length scale can be 10% of a characteristic dimension
Old   February 21, 2000, 07:36
Default Re: k-e
K.L.Huang
thanks,but... how is the turbulence intensity ?
Old   February 21, 2000, 08:49
Default Re: k-e
allan
turbulence intensity is defined as the fluctuating velocity component divided by the nominal velocity, typically 10% is a combustor 1%-6% in a wind tunnel. Have a look at the values they use in the tutorials or the user guide
