Home > Forums > CD-adapco
question
Old   March 25, 2000, 08:04
Default question
K.L.Huang
Hi.
Sorry for my poor English,at first.
I have some question about CFD.
1.I have built a model with Tet mesh, but I find it's very difficult to converge, even I solve it by SIMPISO method. But when I reduce the relax factor of velocity(0.125) ,pressure(0.1) ,TE(0.25) , and temperature(0.8), I find it converge slowly.So my question is what is the function of relax factor? and such a low relax factor will affect the solution or not?
2.In the issued news of Star-CD, they say that they have solved the Coal combustion problem. How do they treat the fine coal particle. According to the tutour 9.5 and 9.6, the two phase lagrange method were introduced in case of C7H8, but in case of C, I think there is no such a evaporate pressure and the liquid phase, how do you solve such a question in droplet method?
3.Continue question 2. If I try to solve coal combustion in Euler method. That is, I treat the Coal as scalar(fine coal particle is conveyed by air), how do I set up the boundry condition.
If u have experience in the above question, please help me. Thank you.
K.L.Huang
Old   March 29, 2000, 04:57
Default Re: question
Peter Stephenson
I have had some successes with coal combustion in v 3.050 but I haven't yet had any success with v 3.100A. CD staff are helping me with this. The particle initial sizes are specified as part of the 'droplet parcels' initial conditions. The theory is in chapter 10 of the v 3.10 Methodology manual.
I have also written a very simple Euler coal combustion model (also in v 3050) and got it to work (by using some user-supplied subroutines). The coal appears as a scalar, so you just specify its inlet value in the usual way for scalar boundaries. If I remember correctly, I had to write my own subroutine for the density, to make sure that I had got an 'effective' density (ie allowing for coal and air or gas in each cell). That way, you also get the correct inlet mass flow rates for air and fuel.
I hope that helps
Peter Stephenson
Thread Tools
Trackbacks are On
C question kar OpenFOAM Running, Solving & CFD 26 May 20, 2008 06:05
Question concerning VOF Flora FLUENT 2 July 9, 2007 09:50
question about LES gino briganti FLUENT 3 June 27, 2005 06:05
The question about Y+ rambol CFX 2 November 7, 2002 10:40
Another UDF question Christian FLUENT 7 July 23, 2002 04:19
