-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   date contour (http://www.cfd-online.com/Forums/cd-adapco/52396-date-contour.html)
Rachid May 31, 2000 05:25
date contour
hay
i have a contour plot from starcd for xy and w axial velocity, but a like to extract the date from starcd it is possible or not thanks
philip June 1, 2000 03:21
Re: date contour
Prostar can output data in many formats, it is up to you to choose the most appropriate for your application
In no particular order Prostar can
output data in the majority of standard forms as recognised by commercial packages such as Tecplot, Ensight Fieldview
output raw data in ASCII files using SAVUSER: Writes a file containing the vertex or cell post data
output graph registers SDATA Saves graph register data values into a file
If this is not enough for you both STAR-CD and Prostar provide hooks for the user to access all the main data structures.
Regards
Philip
