Home > Forums > CD-adapco
francis turbine with cfd
Old   July 11, 2000, 21:41
Default francis turbine with cfd
i'm investigating flow in francis turbine runner with cfd software. i wonder if anibody can give me some advices or any work that has been made successfully. thanks alot
Old   July 15, 2000, 19:11
Default Re: francis turbine with cfd
I do torque converter analysis w/starCD, which should present similar problems. But first: who have you worked with at Adapco? Also, what sort of original geometery info do you have to start with?
The torque converter's turbine component is similar to the Francis. I model a single blade centered in a flowfield that is a slice of the entire turbine. The size of the slice is an exact fraction of the number of blades used; for example: if the turb. has 29 blades, the slice is 360/29=12.414 degrees wide. Cyclic symmetry is used, with integral matching between the 'sliced' faces (means the cell faces must match EXACTLY).
Need help, drop me a line. BTW: I am in Plymouth Michigan.
Thread Tools
Trackbacks are On
GAMM Francis Turbine Mukkarum FLUENT 2 March 22, 2014 12:26
Horizontal Francis Turbine mukkarum Main CFD Forum 0 October 15, 2002 06:03
Francis Turbine mukkarum Main CFD Forum 2 October 14, 2002 00:58
Francis Turbine mukkarum FLUENT 6 July 24, 2002 05:01
francis turbine runner using cfd nizam Main CFD Forum 0 July 11, 2000 23:56
