File compatibility between UNIX platforms
Old   July 12, 2000, 06:51
Default File compatibility between UNIX platforms
Steve Amphlett
Does anyone know how I can export a model from a HP/SGI/IBM/Sun so that a DEC Alpha can read it. I.e are there any tools with STAR for changing the byte order in the .mdl file?
Thanks,
Steve
Old   July 12, 2000, 09:14
Default Re: File compatibility between UNIX platforms
steve
Steve, In later versions of prostar 3.1, there is some new code to recognize byte ordering on the alpha and read appropriately. In older versions, probably the easiest thing to do is "CDSAVE", copy the ascii files over and then ifile the .inp file to reconstruct everything.
Steve
Workbench 11-Linux Intel EM64T platforms Seg fault Maciej Karczewski CFX 5 April 19, 2010 03:37
platforms for fluent mike3 FLUENT 0 April 6, 2007 06:22
Multiple Platforms xc FLUENT 0 June 22, 2005 11:55
Import iges file into CFX5.4.1 in Unix system yli CFX 2 May 5, 2003 08:49
intel platforms to fluent. Carlos Latorre FLUENT 5 January 11, 2000 09:08
