help needed: cone-shape surface
Old   July 29, 2000, 16:25
Default help needed: cone-shape surface
Y. Guo
Hello, there, I am new user of Star-CD.
I want to generate a cone-shape surface(or patch) through Star-CD. What procedue should I follow? The equation of the surface in cylinder coordinate is z = a*r, theta belong to [0,2Pi], a is a constant.
Thanks,
Old   July 31, 2000, 06:31
Default Re: help needed: cone-shape surface
Astrid Hostrup
Hi One suggestion could be that you use a loop to create vertices with the above formula, and connect them with a spline. It should then be easy to make the mesh with the block-command. I don't know if there is a more simple way to do it.
Old   July 31, 2000, 08:19
steve
!Set yourself to the global cylindrical system CSYS,2 !Define 2 points at either end of the cone !(fill in r1,r2,z1,z2 with real coordinates) V,1,r1,0,z1 V,10,r2,0,z2 !fill the line VFIL,1,10 !sweep the line around in theta (every 10 degrees) VGEN,36,10,1,10,1,0,10.0 !plot them VSET ALL VIEW,1 VPLOT
Old   July 31, 2000, 11:37
Default How can I generate the mesh with the vertex?
Y. Guo
Thanks for your kindly help. I have generated the vertexes following your suggestions. How can I generate a patch(mesh) with these vertexes? I looked the patch command. There is a parameter 'ICSRF' which seems related to curved surface. However I do not know how to use it. Could you please help me again? Thanks.
Old   July 31, 2000, 17:56
Default Re: How can I generate the mesh with the vertex?
steve
!define a shell in the cell table CTAB,10,SHELL !define a cell and then sweep it 9 in first direction !and 36 times in 2 direction
C,1,2,12,11 CGEN,9,1,1 CGEN,36,10,1,9
!finally merge the 2 overlapping ends
VMERGE ALL
drag of cone Ebrahim FLUENT 2 March 19, 2008 05:21
Help needed with free surface simulation Mark CFX 4 October 27, 2006 12:07
surface shape chanes by deposit Zhou FLUENT 0 June 12, 2005 05:14
Nose-Cone PAUL MERRILLS Main CFD Forum 0 May 20, 2000 08:44
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed Ricky Wong FLUENT 1 May 11, 2000 17:35
