-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Cell numbering convention (http://www.cfd-online.com/Forums/cd-adapco/52428-cell-numbering-convention.html)
Hassaneen August 6, 2000 05:47
Does any one know how to let STAR-CD number cells in X-direction instead of Y-direction (1,2,3,4...in X-D) Thanks
Tara August 6, 2000 15:47
Re: Cell numbering convention
Hi Hassaneen,
You can you the CDIR command to change the numbering scheme in terms of a local mesh direction. (page 3-18 of the User Guide). Once this is defined, you can use the RESTRUCTURE command to reorder the vertices of a given cell set.
Hassaneen August 7, 2000 04:23
Please be more clear because that manual is not. How could I excute that command CDIR. Thanks =Ahmed=
Stephan Meyer August 7, 2000 07:49
Hello, Ahmed,
try HELP CDIR in the prostar command prompt.
Stephan
Hassaneen August 7, 2000 11:50
Stephan, this code will drive me crazy. I couldn't do it even with HELP CDIR. Do you have any suggestion. Thanks =Ahmed=
Hassaneen August 7, 2000 12:36
Stephan, just now I changed the numbering of the Vertices but the Cells don't change accordingly.??
Stephan Meyer August 9, 2000 02:45
Hello, Ahmed,
You're right. I didn't manage to change the cell numbering, too. This is what I tried:
vc3d,0,10,10,0,10,10,0,1,1
cset,all
numb,vert,on
numb,cell,on
view,0,0,1
cplo
creo,all,,,1,x,y
creo,done
y
cplo
This actually renumbers the cells, but not exactly like I wanted to. It looks a bit like rubik's cube. The first ten cells are in the lowest (seen in y-direction) row, but not numbered in x-direction. The commands
cdir,1,122,133,123
rest,1,repl,defa,renu,101
only renumber the vertices.
What You can do is write the cells and vertices to ascii-files and sort them with another program (e.g. write one Yourself in fortran or any other programming language). You need to do the following steps for this:
1.) write the vertices to a file:
vwrite,star.vrt,0,all,,code
see HELP VWRITE for the format of the file
2.) write the cells to a file:
cwrite,star.cel,0,all,,all,code
again see HELP CWRITE for the format of the file
3.) get the centroid coordinates of each cell from the two files You have written out
4.) sort them
5.) change the cell number in the cell file (e.g. in star.cel)
6.) read the cells back into prostar:
cread,star.cel,0,all,,add,code,0,0
since You haven't changed the vertices, it's not necessary to do anything with them.
I hope this helps. Maybe anyone else on this forum has a better idea???
Stephan
Hassaneen August 9, 2000 04:13
Stephan, my friend: Some how I have got the cells numbered in the way I want. That was achieved by using the tut.cel and tut.vrt from their tutorial (tut13.1). They are using the same tech. you are explaining. Have you got any experience with moving grids in Piston engine simulation Stephan?? if yes, I have a question for you. Thanks =Ahmed=
Stephan Meyer August 10, 2000 12:26
Hi, Ahmed
I've done some simulations with moving grids, but not especially for pistons engines. Anyway, just ask Your question, I'll try to help, if I can.
Stephan
Hassaneen August 11, 2000 02:40
Dear Stephan, Thanks a lot for your help in changing the numbering order for the vertices. For the moving grid, I got my problem working now after a huge effort. Thank you again, I appreciate. Regards =Ahmed=
Hassaneen August 14, 2000 03:36
Dear Stephan, By chance I've got the cells numbered the way we need it. That happen when I was trying to create a 2-D shell and then create a 3-D mesh from it. The code already numbered the cells in the X-direction. =Ahmed=
