HPC problem on DEC
Old   August 10, 2000, 12:58
Default HPC problem on DEC
Steve Amphlett
Anyone know what this means?
[ 0] MPID Die - ump2main.c:299 "Host Mapping was not exported" (0) [ 1] MPID Die - ump2main.c:299 "Host Mapping was not exported" (0)
I'm trying to do a 2-CPU STAR-HPC job using MPI on a DEC. From the run script, it looks like it's using MPI140. The job runs fine on various SGIs.
TIA,
Steve
Old   August 10, 2000, 14:37
Default Re: HPC problem on DEC
Jeff Hank
Steve,
I've never seen that error message before. I've only run on HP machines, but I experienced some trouble when trying to run with HP's own MPI implementation and instead use MPICH.
Are you using DEC's own MPI library or something else like MPICH? Is the hostfile.mpi file getting copied to the first node properly?
Jeff
Old   August 14, 2000, 05:20
Steve Amphlett
Jeff,
Thanks for the reply, but I think I've got it sorted now. For reference, I'm using DEC's own MPI, but my version was 180, whereas STAR-CD comes with 140 and the two are incompatible.
- Steve
Old   October 5, 2000, 03:53
turboguy
Dear Steve,
Did you solve the HPC problem on the compaq machine? I had experienced samm trouble. However, I solve that problem. If you need my help, please let me know. Regards
Turboguy
Old   October 5, 2000, 04:26
Steve Amphlett
Yes thanks. Someone got me a version of STAR compatible with MPI 180.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
