Home > Forums > CD-adapco
expansion
Old   August 29, 2000, 13:15
Default expansion
Isa
Hi, I am working with a problem of expansion and uniform flow. The problem is that I want to uniform the flow when the expansion end, for this reason I put a porous media zone in the end of the expansion, but I have recirculation in this zone, I don't know if somebody know how to simulate the uniform flow when I have expansion?
Old   August 30, 2000, 01:46
Default Re: expansion
John C. Chien
(1). The flow separation is controlled by the expansion. So, with the geometry fixed, you will see the flow recirculation. (2). But if you put the porous media or flow straightener at some distance downstream of the end of the expansion, it is possible to make the flow more uniform. (3). The suggestion is : move it further downstream, and check the results. It is not a good idea to put the porous media zone in the middle of the flow separation, put it behind it.
Old   August 30, 2000, 15:39
Isa
Thanks for your suggestion, but in this case I can't move the flow straightener, because it is a physical condition. In your experience do you know another way different to porous media to simulate flow starightener like a grid or tubes bank?
Old   August 30, 2000, 16:52
John C. Chien
(1). If the expansion is smooth (not a sudden expansion), then , in principle, you can put in some guide vanes to keep the flow attached through the expansion section. (2-D, or annular, depending on the duct or pipe section) (2). In this way, you can eliminate the flow separation in the expansion section.
Thread Tools
Trackbacks are On
Unsteady Jet Expansion Hadley FLUENT 1 October 16, 2013 04:12
Free jet expansion coastal593 OpenFOAM Running, Solving & CFD 6 December 21, 2010 15:14
Supersonic expansion aap OpenFOAM Running, Solving & CFD 3 February 22, 2008 04:29
expansion V.U.Senthil Vadivel CD-adapco 4 December 15, 2005 09:08
ice expansion erik Main CFD Forum 1 January 20, 1999 08:33
