December 18, 2000, 09:49 |
negtive density
Trying to run transient analysis, the run stop after
the first iter. message is like STEP UVEL VVEL WVEL MASS T EN DISS ENTH U V W P TE ED T 1 1.93E-02 2.41E-05 6.43E-02-4.74E-02 9.69E-01 7.81E+03 1.36E+04 -1.86E+00-6.49E+00 1.63E+02 1.28E+03 2.24E+02 1.99E+06 6.02E+02 Warning - starwatch daemon is not registered, no information sent to starwatch. *** ERROR #076 *** NEGATIVE DENSITIES FOUND AT MORE THAN 100 CELLS. RUN STOPPED what wrong of my model set-up |
December 18, 2000, 10:04 |
Re: negtive density
Hi
Does your time step meet the courant equation? (Cr = (v * t)/L ,where Cr = Courantnumber of a cell, v = velocity of fluid in this cell (compressible: velocity of fluid + speed of sound), t = time step and L is the length of this cell) The max. Cr shouldn't exceed 50 - 100. |
December 20, 2000, 04:29 |
Re: negtive density
If you do have moving mesh (events module) you may try to reduce the time step length.
December 20, 2000, 04:33 |
Re: negtive density
Another thing to you and to the others who has the same problem you may try the MARS differencing scheme and don't ask me why because I don't know why but it works.
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 01:40 |
mass density or weight density | jaichan | Main CFD Forum | 0 | April 2, 2006 18:45 |
density of NO2 and COS | j | Main CFD Forum | 2 | May 22, 2003 09:42 |
density of NO2 and COS | j | Siemens | 0 | May 21, 2003 05:12 |
how to set the density | xqy | Phoenics | 3 | January 20, 2003 06:06 |
