How to use F77 compiler in Star-cd.
I used Star-cd V3100 for Win NT 4.0 to solve a engineering problem. When I run STAR, it tells the F77 compiler can't be found. When I installed Star-cd, there was no F77 in my computer. How can I set the enviorment parameter to let it find the path of F77?
Thanks! |
Re: How to use F77 compiler in Star-cd.
Hi, You need Absoft Fortran for WIN/NT, in case you need the user sub-routines. In case you are not using user sub routines, While running STAR from STAR Launcher, STAR--->Options select, DYNAMIC Memory - (either single precision or Double precision).
It does not require FORTRAN Compiler. It is a good idea to Try ver 3.100A. Regards, AK Balasubramanian |
