a better sensor
Old   January 18, 2001, 12:50
Default a better sensor
achim
since a sensor returns the value of the surrounding cell, coarse grids again cause problems when comparing experimental data with data from cfd analysis....
has someone already written a macro or an external program, that does some interpolation on arbitrary vertices or sensors ?
how do i quickly find out which cell encloses the sensor or a vertex that is not connected with the mesh ?
regards, achim
Old   January 19, 2001, 15:39
Default Re: a better sensor
steve
First if you load vertex data instead of cell data, then sensors do interpolate.
After you do a sensor,scan if you do a sensor,list it will tell what cell its in.
Sensor- problem W.A. Siemens 4 June 1, 2006 10:53
OFILE SENSOR guest7777 Siemens 0 April 20, 2006 05:12
modelling for pressure sensor simon FLUENT 0 September 29, 2005 15:31
Sensor points Aline Siemens 2 August 16, 2004 09:52
A problem about the sensor points Lee Siemens 3 October 31, 2003 13:32
