Home > Forums > CD-adapco
FreeSurface simulation
Old   January 27, 2001, 07:08
Default FreeSurface simulation
Chengxuan Fu
Hi,guys
i am doing an CFD analysis of a highspeed waterjet. water is pushed through a very narrow slit into a mixing chamber, where it is mixed with air ,which is accelerated by the water, and sand will be sucked into that chamber. In the end, the mixture injects out of a focusing tube with speed up to 300 to 400 m/s, and metal like Al could be cut by such a machine.
To obtain the necessary speed of water, the slit has to be very narrow, around 10um, and we need very high Psta, 200Mpa to 400Mpa.
i am doing a freesurface simulation , to see how water is interacting with air in the chamber and focusing tube.and i want to optimize the geometry of the design with the results from CFD.
But the problem now, is the calculation is very slow and i need hundreds of PISO corrector stages .
my questions are
1.how to speed up the calculation , yet let it still converge
2.is there any way to disable .info file, because i tried to use AMG method, then the info file became extremely large
3.what is the advantage of AMG method
4.my Re number ranges from 1500 to 15000 in the whole model , which is not completely full with one phase, what kind of turbulent model should i choose
5.in which cases should i turn on subcycling
thanks chengxuan fu
Thread Tools
Trackbacks are On
Initializing freesurface in 3D geometry jaswi OpenFOAM Running, Solving & CFD 9 August 20, 2008 13:27
Effects of turbulence on freesurface sek OpenFOAM Running, Solving & CFD 4 March 22, 2008 22:48
Need following paper about freesurface analysis Morteza Main CFD Forum 1 July 13, 2006 13:32
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
Can Star-Cd REALY run freesurface and Lagrange Mod K.L. Huang CD-adapco 0 September 20, 2002 02:22
