Beginner question – mesh generation.
Old   February 22, 2001, 05:48
Default Beginner question – mesh generation.
Oleg Melnik
Dear StarCD users,
I an a beginner user of this package. I try to calculate flow in a simple axially symmetric domain z=[0,h], r=[0,R] originating from a supersonic jet inflow from the region r=[0,r1]. The boundaries are: z=h, r=R – outlet, z=0, r=[r1,R] – wall. The problem is 2D.
The question is how to generate a mesh. I would like to have gradual increase in mesh size from r,z=0,0 in both direction for example as a geometric progression. What commands should I use to do it? Shell I generate a 2D mesh and make 3D from it by assuming symmetry conditions (what mesh type should I use then – fluid, shell or other) or I should generate a 3D sector?
Best regards, Oleg Melnik
Old   February 24, 2001, 10:00
Default Re: Beginner question – mesh generation.
Antje
Hi!
It is not very easy to explain how to generate a mesh.
Tipp: lock at the help-manuell, read and try the tutorials. You can use the Star-Guide to lean the Commands who are write to the commando window. In the help manual is a List of Commands. Wenn you Know which Command can be usefull: type help >Command> read.
Antje
Old   February 26, 2001, 02:39
Oleg Melnik
Thanks Antje,
I've got macros that will generate the mesh.
Oleg
question from ICEM beginner Jiuan CFX 1 March 6, 2009 18:41
URGENT: HELP ICEM beginner mesh generation car guest7777 CFX 13 October 15, 2007 05:25
LES beginner question Shuo Main CFD Forum 4 July 9, 2007 08:40
Question from a beginner Arun K Main CFD Forum 4 August 13, 2004 07:17
QUESTION IN GENERATION OF BODY-FITTED MESH James Zhu Main CFD Forum 0 September 19, 2000 04:06
