-   Siemens (https://www.cfd-online.com/Forums/siemens/)
-   -   How to generate a postscript file or a tif file? (https://www.cfd-online.com/Forums/siemens/52556-how-generate-postscript-file-tif-file.html)
Ming-Jyh Chern February 28, 2001 22:18
I am just wondering how to generate my results in either postscript or tif format after data visualization in STARCD. Does anybody tell me detail procedures?
Thanks,
Ming-Jyh
Wassermayr March 1, 2001 02:23
Re: How to generate a postscript file or a tif fil
In Prostar GUI there is a toolbar: 'Utility' --> 'Save Screen As'; You may choose: XWD,GIF,PS,EPS
bala April 7, 2001 04:28
you may also take a snap shot of the graphical screen using snapshot application program available on most unix systems and save it in what ever format you want
philip April 11, 2001 03:49
To get a plot out of Prostar, plot to file rather than screen. This produces a .plot file. Then use the plot utility to convert the plot file to postscript or other format you want.
For bitmaps there are three approaches:
1) Use the scdump or save as options from the GUI: quick but only at screen resolution so OK for presentations but lousy for printed matter
2) Plot to file, convert to Postscript and then rip the postscript using ghostview: good quality for printing
3) If you are using the extended mode, then plot to file does not use the hardware acceleration so you get a non-extened version: so you can use option (1) but if you want extended and high quailty then you need to tile the image: contact me directly for info on this
Regards
Philip
nico June 5, 2001 13:07
you could also use the function save screen as
