March 1, 2001, 05:22 |
Stream lines in Prostar
I did not get answer for the last question and I hope this one will be easier. I like to plot stream lines in Prostar or another softwares. It seems that it can not be done by usual prostar commands. Does anybody have a macro to do that or do I have to use another software. If a macro exists, please indicate me where I can find it. If there are softwares which are compatible with Prostar results and allowing this kind of plots, please say me which one? Thanks for your help. Bjorn |
March 3, 2001, 09:42 |
Re: Stream lines in Prostar
Hi,Bjorn You can do it with STAR GUide. First, you go to this menu: Post-processing -> Particle Tracks Then click the 'Options' menu,you can find a new menu as 'Particle Tracking', what you want to do is just fill this menu. It is very easy and good to plot steam line. Good Luck. Regards/Yang
March 5, 2001, 09:01 |
I do not well understand because I think that stream lines and particles tracks are not the same lines.
1) For particle tracks, you try to get x(t),y(t),z(t). That means that you follow a particle in the flow. 2) For stream lines, you have to solve : dx/U=dy/V=dz/W which gives you field lines vec(V). So, sorry, Bjorn, but I do not have any answer to your question. Regards Vincent |
March 5, 2001, 10:22 |
You can plot streamlines only for 2d-problems. Use command getv stre.
Display Modes | |
Input - Stream lines | AJG | FLUENT | 2 | March 24, 2013 07:52 |
Mpeg for Stream lines | Haroon Junaidi | FLUENT | 2 | October 30, 2007 14:01 |
PROSTAR | Emmanuel Resch | Siemens | 7 | August 1, 2006 09:37 |
stream lines | caimoto | Siemens | 0 | August 26, 2001 07:36 |
Stream lines distance | ram | Main CFD Forum | 0 | November 11, 2000 04:31 |
