NT 4.0 installation
Old   July 3, 2001, 07:02
Default NT 4.0 installation
peter.liang
I am installing the NT4.0 after WIN95. The DOS command prompt indicated that: " C Disk is not formatted or C was damaged ". Press Enter to exit.
How can I do then?
by the way, I installed Office97 in win95, everything works fine.
Many thanks.
Old   July 4, 2001, 06:25
Default Re: NT 4.0 installation
Thomas
Well, that seems to be the problem with Microsoft operating systems. I did the same and the only way seems to be to install NT first and then Win95/98. When installing Win95/98 it normally uses the FAT32 file system which NT doesn't support. So you need a FAT16 partition to install both operating systems.
I didn't find any other solution, maybe there exist one, but I do not know.
Hope this helps,
Thomas
Old   July 4, 2001, 12:52
peter.liang
Many thanks.
My pc is from TOSHIBA, the Win95/98 options are given by default, seems, I cann't install NT4.0 first.
AMD 64 bit installation maka OpenFOAM Installation 7 January 11, 2009 10:42
Regarding installation vidyaprakash Siemens 0 December 21, 2006 23:03
HP Installation ali OpenFOAM Installation 7 August 18, 2005 16:28
installation mohammad FLUENT 0 May 4, 2003 10:15
HP-UX installation new here FLUENT 1 October 26, 2000 21:54
