couples in ver 3.100B
Old   July 5, 2001, 06:38
Default couples in ver 3.100B
Bo Jensen
Hallo
I have just switch to ver 3.100B on a windows 2000 platform. I have some old models created in ver 3.100A that I would like to run in 3.100B. The model has some twisted couples but they could work in ver 3.100A. Now trying to run it in ver. 3.100B tells me that the faces of some couples are not close enough to be valid for slave cell and face. Any one got an idea to solve this problem.....
Regards
Bo
Old   July 10, 2001, 06:37
Default Re: couples in ver 3.100B
J. Y. Luo
I believe PROSTAR has implemented a new improved scheme to check matching quality. There are two things which you can do: 1. if you are happy with the v3.100A couples, then simply use NOCHECK option when writing geometry file: GEOMW,case.geom,,,nocheck. 2. delete existing couples and match them again in v31.00B. Hope this helps.
Cell Couples in CCM+ norbinou Siemens 4 September 10, 2007 10:00
about couples bv Siemens 1 July 24, 2005 07:05
couples issue carno Siemens 1 April 16, 2004 02:58
Boundary Couples ale Siemens 0 January 26, 2004 05:09
couples or not couples... giosue Siemens 5 March 1, 2003 00:11
