switches option
hay people
how i can use switches option the modified the relaxation factor during the calculation. thanks |
Re: switches option
enable switch 50
then write your problem file. A file "casename".ctrl is created which contains the relaxation factors etc. This is visited every iteration this can be edited and therefore the relaxation factors can be changed easily. allan |
Re: switches option
Hay Allan
i can do that during the calculation via starcd window or via unix schell Tahnks |
Re: switches option
you need to set this up before you write the problem file. You cannot initiate this after the calculations have started.
cheers allan |
