Home > Forums > CD-adapco
why can't I plot Y+ value?
Old   August 16, 2001, 15:46
Default why can't I plot Y+ value?
Jiaying Xu
Hi, friends,
I encounter a problem while trying to plot out the Yplus value.
The case is to study a 2D cross-single-cylinder flow. I use LRN turbulence model and want to check the Yplus values at the cylinder surface. When I load the Yplus data and press pull-down menu Plot > Wall Plot, nothing comes out and the OUTPUT window says "You have not loaded any data".
An additional question: when I loaded the wall data, prostar told me to enlarge MAXCEL. I did, and loaded the data successfully. But I saw lots of shell-type cells were created. The question is that I cannot plot them via CPLOT! prostar always told me "** Warning - no cells to plot **Error - no items selected for plotting" but I can see all shells in the cell set! And what is strange is that I have to put them in or delete them from cell set by issueing command CSET. I can not use graphic button C > New (or Delete) > Type(Current) to operate these, I did activate the type I want to operate. If I tried these with graphic button, the commands recorded by OUTPUT window are actually to operate upon cell type 1, not the active type! thus no cells are added to or deleted from the cell set.
Why is it?
Help is urgently needed, please!
Jiaying
Old   August 17, 2001, 08:43
Default Re: why can't I plot Y+ value?
Stephan Meyer
Hello, Jiaying,
the y+ plotting in prostar is really kind of strange.
Here's a brief description of how to get a y+ plot:
1.) Select the shell of the boundary whose y+ values You want to see (when using the GETW command, prostar tells You what shell cell types are created for the different boundary regions). Alternative: use CSET ALL.
2.) Switch plot option to contour plot (POPT CONT) and plot type to hidden surface (PLTY EHID).
3.) Do a wall plot (WPLO)
Hope this helps!
Stephan
Old   August 18, 2001, 10:56
Jiaying Xu
Thanks, Steve! I've got the yplus plot as you hint.
Thread Tools
Trackbacks are On
plot y+ vs x Sara CD-adapco 1 August 7, 2008 17:43
3d plot heri FLUENT 0 April 30, 2008 13:39
How to plot Y+ vs. U+ ? Wael CD-adapco 0 March 13, 2006 20:21
FFT plot Farrukh Shahab FLUENT 1 October 13, 2005 01:54
Re vs St plot Allan Cross Main CFD Forum 2 March 25, 2005 20:09
