Vorticity magnitude
Old   August 20, 2001, 09:40
Default Vorticity magnitude
Hernani
Hello
How can I calculate the vorticity magnitude (= |rot(V)|) and then, how to visualize it along with other variables as velocity or pressure? Do I have to write a sub-routine? If so, how? The manuals aren't quite explicit about building users'subroutines... It may be easy. But I'm still a novice with Star-CD. So any help is welcome and will be rewarded with my deepest and eternal gratitude. Thank you
Old   August 20, 2001, 09:43
Default Re: Vorticity magnitude
Joern
oper(ate), curl
try also "help operate"
Old   August 20, 2001, 09:48
Hernani
Thank you very much Joern. I'll try that.
Vorticity magnitude CFD-junior Main CFD Forum 10 October 8, 2021 03:42
y+ and velocity magnitude Simone Main CFD Forum 3 December 12, 2008 06:44
To get the magnitude of volVectorField susana OpenFOAM Pre-Processing 5 November 16, 2006 06:53
Could vorticity magnitude be ploted ? w0er Main CFD Forum 4 February 8, 2005 07:49
on velocity-vorticity & stream-func-vorticity yfyap Main CFD Forum 1 March 23, 2001 03:00
