Home > Forums > CD-adapco
errors for right-handed grids
Old   August 30, 2001, 10:55
Default errors for right-handed grids
x. yan
Hi everyone,
i tried to eliminate the left-handed grids in my mesh, following the star guid folder check and fix grid > right handed > apply and then fix grid problems>flip right the problem grids, i have also used the command cflip, any of them works, can anyone tells me why and how to change it.
thanks a lot
Old   August 30, 2001, 11:33
Default Re: errors for right-handed grids
HVN
try Check tool (located near the cell tool) with check option : Right Handed.And click Fix left-handed
Old   August 30, 2001, 11:47
x. yan
hI;
i tried this method too, it didn't work. Any idea?
Old   August 30, 2001, 14:03
Joern Beilke
What sort of mesh are you using? Maybe some of your cells are very bad distorted. Have you checked the remaining lefthanded cells manually to see whats wrong with them?
Old   August 31, 2001, 07:29
Helge
That is also my experience. If there are still right handed cells after the correction the reason always was that there are very bad shaped cells. You have to move nodes by hand to reshape them. I know that it is very hard to move nodes within prostar. If you like I can send you a macro which helps a bit.
And after that you should not use any smoother because they normally are redoing your operations.
Thread Tools
Trackbacks are On
Fluent Grid Check: Left-handed & right handed face Haider FLUENT 3 March 23, 2009 00:01
What is right- and left handed magnus wikander FLUENT 2 December 1, 2004 12:34
left handed guang ai CD-adapco 2 March 28, 2004 02:02
right-handed cells co2 FLUENT 0 December 26, 2003 21:07
Left Handed faces ff FLUENT 4 October 17, 2003 09:34
