How to generate the mesh on the surface in prostar
Old   September 11, 2001, 22:12
Default How to generate the mesh on the surface in prostar
raymond
I want to set up the grid system in the prostar, at first, I create four closed splines with two vertices at each end and add some fixed vertices on each of splines. Then I want to create shell with PATCH command. Then the problem is that I could not divide the patch with the cell that just passing through those fixed vertices. Should I do PATCH command one by one?
Old   September 13, 2001, 05:48
Default Re: How to generate the mesh on the surface in pro
Philip Jones
If you want to match exactly a vertex on a spline then you need to mark those vertices with a negative sign (used for discontinuities) and the prostar does its best to match these vertices:
Philip
Need someone to generate mesh RA FLUENT 7 May 4, 2007 11:36
[Other] Problem when trying to generate a new mesh gaottino OpenFOAM Meshing & Mesh Conversion 0 June 30, 2006 07:51
Mesh Generation using Prostar Anindya Siemens 3 June 5, 2001 07:40
How to generate grid system with a curved surface Jing Ren Siemens 3 March 13, 2001 11:58
Gambit -> Prostar mesh ? sangrar FLUENT 1 March 6, 2000 04:26
