2D Axi-symmetric Case
Old   September 25, 2001, 01:23
Default 2D Axi-symmetric Case
Anindya
How can I build a 2D Axi-symmetric model in STARCD ? I want to use the r-z co-ordinate system. Thanks
Old   September 26, 2001, 09:52
Default Re: 2D Axi-symmetric Case
HVN
Use csys 2 to use r-z coordinates. For 2D mesh, you need to make a make with one layer of thickness with symmetry boundary conditions on both sides.
Old   September 26, 2001, 11:17
Anindya
Thanks HVN. I will try your sugestion. So in the cylindrical system, I choose a small angle with only one divison ?
Old   September 26, 2001, 11:20
HVN
Not necessary. because you have one single layer with 2 symmetries. You could take normally any kind of angle. You could see some examples of 2D studies in tutorials.
How to specify the axis in 2D axis-symmetric case? B FLUENT 4 February 9, 2009 10:09
Flow about symmetric shape is not symmetric PetrK CFX 7 August 23, 2006 12:54
Symmetric BCs mao Main CFD Forum 5 May 19, 2005 10:11
UDF for 2d axi-symmetric case Manoj FLUENT 0 October 11, 2004 13:00
UDF in axi-symmetric case manoj FLUENT 0 October 7, 2004 07:01
