command to output run information?
Old   October 16, 2001, 09:21
Default command to output run information?
x. yan
Hi, sometimes i get a long list of errors which is out of scoll limit in the prostar output window. these errors contain the same information for a huge number of cells. usually i can only get to know a (last) part of cells that are wrong, with the first part missed. Is there a star command that can write the run informatin in a extra file (not displays in window) so that i can read all the error cells?
Old   October 16, 2001, 12:39
Default Re: command to output run information?
steve
Yes, use OFILE,some_file_name. This will send all your output to "some_file_name". To send it back to the screen use OFILE,SCREEN.
Old   October 17, 2001, 01:56
Anton S. Lyaskin
Almost all check commands have an option (which is on by default) to put failed cells in a new cell set, so you can just look at the list of cells in a set.
Timescale Information in the Output File charles CFX 6 November 8, 2006 15:03
can "output control " output Nu in expression? prayskyer CFX 3 July 7, 2006 19:37
output surface grid information Adam FLUENT 0 May 17, 2004 21:17
Output from the Monitor point command swapnil CFX 0 November 20, 2002 22:08
Text command of monitor-command? Mika FLUENT 0 March 27, 2001 13:46
