-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Segmentation fault (http://www.cfd-online.com/Forums/cd-adapco/52735-segmentation-fault.html)
Jose Sanchez November 28, 2001 20:07
Segmentation fault
Hi Everybody,
I am using Star-CD v3100 in windows 2000 version. While solving an analysis using starlink, the error message "segmentation fault" appears, the same executable is running without problems in a workstation. For this reason I think it seems to be the settings problem in the windows machine...Did some of you had a similar problem? What do you suggest to solve this problem?
Thanks, Jose Sanchez
Julie Polyakh December 16, 2001 09:13
Re: Segmentation fault
Hi, Jose! Maybe there is not enough memory at your PC? Try to clean the memory. Before running a case remove .info-, .bak-, .echo-files.
Regards, Julie
