AIR molecular properties
Old   January 3, 2002, 11:08
Default AIR molecular properties
Julie Polyakh
What options for AIR molecular properties (i.e. density, Cv, conductivity) should I set for compressible flow?
Old   January 4, 2002, 05:54
Default Re: AIR molecular properties
john
Normally IDEAL GAS f(P,T) for density, constant specific heat capacity and conductivity are adequate. If temperature is high, you may also consider Suderland formula for laminar viscosity.
Old   January 4, 2002, 07:59
Julie Polyakh
I obtain the temperature values x2 than they should be. What could be the reason? I have just 2 opposing inlets and pressure boundary (outlet, actually). The velocities are low. No chemistry. Do you have any ideas? (I hope you do
Old   January 5, 2002, 16:25
Julie Polyakh
After I've set the 'Thermal' option for the enthalpy computation the temperature values are OK. But now there is no convergence after 1000 iterations (the enthalpy residual ~0.04).
Unit of Molecular weight clark FLUENT 2 March 15, 2008 05:28
How get Species Molecular Weight in UDF hesam FLUENT 1 April 14, 2007 18:55
molecular properties yann Siemens 6 January 19, 2006 04:33
Molecular Weight Ari FLUENT 0 August 22, 2004 07:36
Microscale CFD and molecular dynamics Robert H. Leyse Main CFD Forum 2 April 4, 2003 11:03
