High temperature problem
Old   January 5, 2002, 14:06
Default High temperature problem
Julie Polyakh
I obtain the temperature values x2 than they should be. What could be the reason? I have just 2 opposing inlets and pressure boundary (outlet, actually). The velocities are low. No chemistry.
Old   January 5, 2002, 16:24
Default Re: High temperature problem
Julie Polyakh
After I've set the 'Thermal' option for the enthalpy computation the temperature values are OK. But now there is no convergence after 1000 iterations (the enthalpy residual ~0.04).
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
Ultra high temperature? bk Siemens 2 July 19, 2005 00:01
Temperature is abnormally high! haiong FLUENT 5 August 29, 2004 02:23
Cp for very High Temperature Flows Arun FLUENT 0 July 13, 2004 12:40
Why temperature is so high? Albert FLUENT 2 June 22, 2003 11:28
