velocity divergence as plot
Old   October 12, 2001, 03:28
Default velocity divergence as plot
Sabatini
Hallo people Is there a way to extract the velocity divergence as plot Thanks
Old   October 16, 2001, 05:56
Default Re: velocity divergence as plot
Paal
I am not fully sure that I get your question right: Do you want to plot the diverged "results"?
These results are saved to a file - case.div, and can be loaded in the same manner as normal result files just replacing the case.pst with case.div
Old   October 16, 2001, 12:11
steve
I think to get what you want you have to load velocities (GETV,ALL) and then use OPERATE,CURL function. I think CURL is the same as divergence of a function?
Old   October 17, 2001, 01:49
Lars Ola Liavåg
The curl of a vector field is itself a vector (cross product of the "upside down" delta and the vector), whereas the divergence (the corresponding dot product) is a scalar. Hence, for the velocity vector V, div V = du/dx + dv/dy + dw/dz, whereas curl V = i(dw/dy - du/dz) + j(du/dz - dw/dx) + k(dv/dx - du/dy), all d's being partial differentials.
In PROSTAR, the OPERATE,CURL function takes the curl of the loaded vector field and returns the curl (vector) of it. You can also calculate the gradient vector, but I don't know how to calculate the divergence in PROSTAR. I guess contacting the support team is a good idea.
Old   January 21, 2002, 09:30
daniel
CURL is definitely NOT the same as the divergence of a function, but a DIV command should also be available the same way
Old   January 28, 2002, 19:07
cfd
Continuity equation:
div(rho u) = d(rho)/dt
For a converged steady state solution:
div(u) -> 0.
For a transient compressible time step solution:
div(u) = 1/rho [d(rho)/dt - u grad(rho)]
For incompressible time step solution: (rho = const.):
div(u) -> 0.
How to represent the divergence of a tensor times a velocity titio OpenFOAM Running, Solving & CFD 0 January 15, 2009 16:51
Velocity plot J CFX 5 October 27, 2008 12:13
divergence-free velocity field - 2D problem pres FLUENT 1 May 31, 2008 12:28
how to plot RMS velocity (fluctuating velocity) nash Main CFD Forum 0 October 18, 2006 16:37
velocity field divergence? gh FLUENT 0 July 6, 2005 11:10
