Home > Forums > CD-adapco
Pressure BC
Old   January 29, 2002, 06:03
Default Pressure BC
Julie Polyakh
What concentration values should be set at the pressure boundary?
If the value is zero does it affect the solution?
Thanks, Julie
Old   January 31, 2002, 10:40
Default Re: Pressure BC
Allan
Hi Julie, If you put this boundary far way from the combustion zone, you can probably use the zero gradient assumption for the scalars. Regards Allan
Old   February 1, 2002, 05:24
john
if the flow is going into the computational domain at the pressure boundary, then the situation is similar to inlet boundary condition, and all scalar quantities have to be specified. However, if the flow is going out, then the scalar values you specified will NOT be used by the code.
Thread Tools
Trackbacks are On
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 12:51
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Forcing pressure outlet according to pressure prob Cedric FLUENT 0 July 29, 2005 11:49
pressure driven flow by pressure correction method justentered Main CFD Forum 0 December 30, 2003 00:52
Total pressure to static pressure ratio roadracer CD-adapco 1 April 17, 2003 05:31
