January 29, 2002, 05:03 |
Pressure BC
What concentration values should be set at the pressure boundary?
If the value is zero does it affect the solution? Thanks, Julie |
January 31, 2002, 09:40 |
Re: Pressure BC
Hi Julie, If you put this boundary far way from the combustion zone, you can probably use the zero gradient assumption for the scalars. Regards Allan
February 1, 2002, 04:24 |
Re: Pressure BC
if the flow is going into the computational domain at the pressure boundary, then the situation is similar to inlet boundary condition, and all scalar quantities have to be specified. However, if the flow is going out, then the scalar values you specified will NOT be used by the code.
What type of pressure can give the pressure drop | david | FLUENT | 1 | February 17, 2014 11:51 |
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet | gabriel | OpenFOAM Running, Solving & CFD | 16 | September 30, 2009 18:20 |
Forcing pressure outlet according to pressure prob | Cedric | FLUENT | 0 | July 29, 2005 11:49 |
pressure driven flow by pressure correction method | justentered | Main CFD Forum | 0 | December 29, 2003 23:52 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
