solar radiation
Old   February 1, 2002, 04:58
Default solar radiation
raymond
I want to calculate the heating effect on the solar radiation through the window to the indoor air in an enclosure. I found in the manual that solar effect is only on the solid surface. How can I define that particular question? Is is nessary to turn on the "thermal radiation" and the "radiation" in the fluid cell type (air)?
Thanks in advance!
Old   February 1, 2002, 05:57
Default Re: solar radiation
stephen
It depends, are you modelling the outside of the building too? If the point of entry into your fluid domain is a window then solar radiation will do just fine, passing through the window until it hits a solid wall beyond.
Regards
Stephen
Old   February 3, 2002, 22:14
raymond
Just as your describtion, I want to simulate the solar radiation through the windows, no outdoor air is needed to simulated. Is that means that i just need to switch on the "solar radiation" button, it will work on the fluid inside the building? Could you say a little bit clearly? Thanks!
solar radiation greg FLUENT 2 August 18, 2006 05:08
solar radiation Arnold FLUENT 0 May 2, 2006 21:00
solar radiation gb FLUENT 1 December 22, 2005 03:16
solar radiation su nam Siemens 0 July 30, 2004 02:17
solar radiation Davide Lucarelli FLUENT 0 October 2, 2001 13:04
