February 18, 2002, 11:11 |
cell refinement in pro-am
i am trying to refine a section of mesh in my geometry uising proam and the cell refinment tool under additional tools in prepare custom mesh. If i go to model organisation and the to refinement and type in values of refinment in i,j,k directions then click refine on the GUI all i get is refinment to the original value in the refinements section NOT the value that i entered. eg. if i have cell size of ten then put a refinement level of 8 in for example then click refine all it does is divide the cells in two. Is there any way of getting round this or is it a glitch?? I am using 3.100b on nt
February 20, 2002, 05:44 |
Re: cell refinement in pro-am
The easiest way to refine cells is with the cmrefine command. This command split cells by 2*2*2 by default and also creates the couples needed to keep connectivity. If you want refinement by a factor 8 you have to use cmrefine 3 times in a row on the same cset, resulting in a factor 8 refinement. If you dont want the same refinement in all directions you will have to use the command cmroption to define which direction(s) you want to refine. This is valid for Pro*AM version 3.103.519 which is the latest official released version. (The latest star version number, 3.150, is different from Pro*AM version number since they are developed separately) I recomend that you upgrade to the latest release of the star-package incl. star 3.150 and pro*am 3.103.519
regards Tobbe |
How to identify boundary cell and internal cell | dbxmcf | OpenFOAM Running, Solving & CFD | 2 | November 6, 2016 09:11 |
cell velocity U and its cell face area | Chinayu | Siemens | 0 | May 6, 2006 22:44 |
unsturcture cell & cylinder cell Difference~ | lenson | Siemens | 1 | January 9, 2006 05:32 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Cell-vertex and cell-centered finite volume method | Praveen | Main CFD Forum | 4 | September 8, 2003 23:58 |
