Home > Forums > CD-adapco
combustion model
Old   February 25, 2002, 05:28
Default combustion model
Hennie van der Westhuizen
I'm trying to introduce the Magnussen combustion model to my SI engine model but at the time of combustion nothing happens. I cannot find clear instructions on how to set the various parameters for this model in the manuals. My parameters are currently:
ufactor: 0.5
mixture fraction: 1
no conditional enthalpy
tscale adjust: standard
reaction: C8H18 + 12.5O2 -> 8CO2 + 9H2O
rate eqn: no products
Amix: 4
Bmix: 0.5
reactant parameters: 02 fixed fraction 0.233
leading reactants: C8H18
products: CO2,
H2O ignition fraction: 0.05
time: iteration
knock model: off
Ignition starts 10 deg BTDC and continues till the last time step.All the scalars have been defined and their concentrations in the cylinder set to:
C8H18: 0.0665
O2: 0.1960
N2: 0.7375
When running the simulation, the fluid temperature in the combustion chamber gets up to 600K due to compression but no chemical reaction takes place.Is there any other parameters I need to set for the model to work? I would appreciate any suggestions.
Old   February 25, 2002, 12:36
Default Re: combustion model
Daniel
My speculation is that since the products switch in the Magnussen model indicates that the reaction rate is dependent on products concentration as well as the reactants, and in your case there is no CO2 in the chamber before reaction occurs, this may cause the reaction rate to be zero.
Old   February 25, 2002, 14:03
Richard
One thing which could be wrong is you say "mixture fraction: 1", whereas the mixture fraction should agree with the fuel concentration (at boundaries and initial conditions).
Old   February 26, 2002, 03:09
Thanks guys for the response. I looked at the concentrations of the scalars in the chamber and it seems that from iteration 1 all combustion products are already formed and all fuel burned. This happens irrespective of what I set the initial scalar concentration to and despite the setting of ignition occurence at iteration 170(10 deg btdc). No heat is released either.
Old   February 26, 2002, 07:24
Daniel
Well, the magnussen model does not require ignition at all, so that is no problem. How did you conclude that no heat is released in your model ?
Old   February 26, 2002, 07:50
The RVB concentration was not set. Setting this value to 1 caused my model to work as this is the scalar determining the concentration of the mixture in the background fluid. Combustion now starts at the first iteration i.e. as you said, no ignition is required. How do I controll the time of ignition in this model?
Old   February 26, 2002, 08:13
Daniel
That is a bit of a problem with the magnussen model, since this is a model of the "mixed is burnt" type. I guess you could just run your model the required number of time steps without combustion, then stop it, turn combustion on and restart the analysis. Expect some problems (convergence, etc...) as you restart.
Old   February 27, 2002, 03:10
Thanks Daniel, I switched over to the standard eddy break up model, which allows control over combustion time. This seems to work quite wel.
Thread Tools
Trackbacks are On
combustion model in premixed combustion chamber wuyu FLUENT 7 October 21, 2015 13:18
Combustion Model Rachel FLUENT 3 November 11, 2008 21:29
Sawdust Combustion-Non-premixed Combustion Model Jessy FLUENT 1 June 19, 2007 10:59
Model combustion KOchzg FLUENT 0 April 4, 2005 10:46
Combustion-which one is an appropriate model? Shankar FLUENT 3 February 16, 2004 16:57
