-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   strange colors of screen capture (http://www.cfd-online.com/Forums/cd-adapco/52832-strange-colors-screen-capture.html)
Jiaying Xu February 25, 2002 08:10
Hello, there,
I am using StarCD, on a remote SGI machine, to produce some pictures of the claculated result. However, I encounter a starnge problem: the pictures always get an urgly yellow background.
It looks just fine on screen but twists the colors of both foreground and background when saved to a file.
This happens when I use ssh on my linux box to connect the SGI, and disappears when use XWin32 (or Exceed) on Windows 98. But I do need to use Linux much more often.
What I have done to try to solve out the problem: 1) issue xstdcmap -all on SGI then initiate PROSTAR; 2) replace /usr/X11R6/lib/X11/rgb.txt on my linux with /usr/lib/X11/rgb.txt on SGI, restart local X server, ssh connect to SGI, then start PROSTAR; 3) the same as 2), but before starting PROSTAR, issue xstdcmap -all.
All these could not get rid of the problem.
Any suggestion to sort out this annoying problem?
Many thanks,
Jiaying Xu
Joern Beilke February 26, 2002 06:38
Re: strange colors of screen capture
plot to the case.plot file and convert the pictures after that. In prostar:
term ,, file rast $ repl
produdes a file cassed "case.plot"
Then run the "plot" command from the command prompt to convert the file to something else.
