Home > Forums > CD-adapco
multi-material in my model--two fluids divided by
Old   March 4, 2002, 19:23
Default multi-material in my model--two fluids divided by
Yun Wang
I met a problem: when I use the multi-material in my model--two fluids divided by a baffle, the geometry writing will give me an error: "adjacent cells are in different fluid streams and not separated by a wall or baffle."
You know, I used the baffle, that is why I was pussled. I even used wall to separate the two type of materials. No use. WHo can give me an advice?
Old   March 5, 2002, 09:03
Default Re: multi-material in my model--two fluids divided
stephen
It means a baffle cell, not a baffle boundary condition.
Old   March 5, 2002, 10:07
steve
If you use separate fluid streams (ie different materials) then they cannot touch each other anywhere. There MUST be a baffle cell separating every location where the 2 streams would otherwise touch. If you are getting the error message, it means that somewhere your 2 fluid streams are directly connected.
Thread Tools
Trackbacks are On
How to connect two part divided by interface xmlu OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 0 March 4, 2009 16:15
mixing two fluids using mixture model fadhil FLUENT 0 June 9, 2008 01:28
Divided by zero German Montalvo CFX 0 August 3, 2007 10:30
Low reynolds model for non newtonian fluids Kimo FLUENT 0 July 22, 2007 11:36
level set for multi-fluids system? Pei-Ying Hsieh Main CFD Forum 1 July 19, 2000 16:42
