Home > Forums > CD-adapco
Porous media...
Old   March 5, 2002, 09:03
Default Porous media...
july
hi... I've to simulate an homogeneous porous media its permeabilty K= 1.7E-11 [m2] Does anybody suggest to me how i have to set up the alfa and beta permeabilty coefficient ? thanks
Old   March 6, 2002, 11:28
Default Re: Porous media...
Jing
They are functions of : volume porosity, molecular viscosity, density and the mean diameter of the particle in the porous. The detailed equations are listd in the manual, you can just use them.
Old   March 7, 2002, 07:09
A.S.Adam
hi I am dealing with the same subject using fluent5.5. but the problem fluent can not present velocity distribution in packed bed.so my question is does Star-CD present velocity disribution in packed bed? and which model they used to solve momentum equation? I look forward to hear from you shortly with best regards A.S.Adam
Old   March 12, 2002, 03:57
july
I Adam ... I'll to tell you what i've got.. StarCD use a linearized form of permealbility function the equation is : -K U = grad P where K = alpha /V/ + beta where /v/ is the velocity magnitude... If you want simulate a porouos media you can use a soubroutine (sormom.f) which introduce sources in the momentum equation... the terms wich the subroutine introduces are two: s1 and s2: the source term id s=s1-s2 *U where s1 and s2 are user defined...
Old   March 12, 2002, 08:57
john YL
In prostar, you can plot velocity distribution in the porous region. STAR uses Darcy's Law for the momemtum equation.
Thread Tools
Trackbacks are On
Free media&porous media.Big changes in properties. Isi Main CFD Forum 1 July 14, 2008 07:18
porous media mikezhang Phoenics 2 September 21, 2002 21:10
Porous baffle and porous media Jan CD-adapco 0 June 8, 2002 09:23
Porous media James Hampson FLUENT 1 January 12, 2001 13:29
Porous media Alberto FLUENT 4 July 20, 2000 05:47
